Dish 1000.4 LNB,AND DISH LNB FOR 110 NOT WORKING TOGETHER. | SatelliteGuys.US
gandlcarr
12
northern maine
Hello all,
just a quick question and has anyone had this issue before,hooked up a eastern arch dish,1000.4,and a dish 500 pointing at 110 for locals.everything tunes in at the dishes with the super sat buddy we are using, hook everything up,do a switch check, not getting 110 sat. swapped the 1000.4 LNB out with another, everything works fine. Bring the LNB back to the shop test it and it works fine. Bring the 1000.4 LNB to another install, does the same thing. Change it out, everything works again. Bring back ,Test at shop, works Great, it is still on our test bed and is working, been on there for around 4 months now. I have had a few 1000.4 LNB do this, is there any reason for this??, Like i stated Using the Sat buddy all Sats Found at the dish,72.7 , 61.5 , and 110, do a switch check inside, not seeing 110.
Thanks In Advance for any help.
Program Info staying on screen
Dish and 3D
