dish 1000.4 and another dish for 110 | SatelliteGuys.US
gandlcarr
12
northern maine
Hello all, i was just woundering , if your using a dish 500 to tune in 110, does the lnb have to be a DP plus, or just a dp? and which one works with a dish 1000.4 port?, This is for getting locals in northern maine. Dish Network sight does not make that clear, they only show a dish 1000.2 and not a dish 1000.4
thanks in advance.
thanks in advance.
I just did this yesterday and I know a DP will work and also think a DPP should work also. I just ran a short line to the in port on the 1000.4 and check switch, of course you have to make sure you have a signal from 110 first.
Thanks alot. Thats what i thought i just wanted to make sure. Thanks for the speedy reply.
You want a DishPro (not DishPro Plus) dual or single LNB for input to a 1000.x dish.
Inlaws cancelled Dish out west ...
Question for Claude
