Diseqc controller? | SatelliteGuys.US
Diseqc controller?
Biggreg
USA
Can anyone point me to a device to manually send diseqc commands without an FTA receiver?
What I'm looking for is a device I can put inline between a diseqc switch and a receiveror spectrum analyzer that doesn't speak diseqc so I can manually select a port on the switch. Does such a thing exist?
two ideas:
I remembered that STAB made some sort of hand-held box.
So, I looked it up. Unfortunately, all it does is command a diseqc motor to move.
What you could do is use the LOOP-OUT of a standard FTA receiver to feed your spectrum analyzer.
Or alternately, you could use a DVB-S PCi card in your computer to send the commands.
(or even a USB DVB-S module on a laptop)
Perhaps someone else will have a better idea.
A Google search for "diseqc generator" turns up some interesting devices that convert four 0/12V inputs into DiSEqC position, option, polarization, and band commands. The first two can be used to control a normal four port switch (the latter two are useless for most LNBs).
E* and single LNB dish with motor?
Free-to -air sellers/installers in Akron/Canton, Ohio
