DISEQ | SatelliteGuys.US
DISEQ
mystic1
2
bahamas
GOOD DAY AGAIN GUYS. JUST A QUESTION. I HAVE A VIEWSAT ULTRA 2000 AND I WANTED TO KNOW IF IT CAN CONTROL A MOTORIZED DSH SYSTEM.IT HAS DISEQ BUT DONT KNOW HOW ITS DONE.OR DO I HAVE TO GO OUT AND BUY ANOTHER RECEIVER?APPRECIATE ANY HELP U CAN GIVE ME ON THIS.
Do you have the manual? It should give you all the info you need to control a DiSEqC or USALS dish motor. If not you should be able to get it from the VS homepage.
Regarding CAPS - FYI, In text based communication, posting in CAPS is considered as yelling, or being otherwise obnoxious. It should be avoided. There are proper uses, as in acronyms, or one means to textually accentuate certain words in ones post.
Satellite Array???
SG2100 CONFIGURATION
