Disable Info on Channel Change | SatelliteGuys.US
fortytwo
2
Hi guys,
Does anyone know if it's possible to disable the 'info' screen from automatically coming up when changing a channel on a Dish 811 box? I've got a MythTV box I built on top of the set top box which already provides the info of a channel, and having both up gets a bit annoying.
Hi guys,
Impossible. It only displays for a few seconds so it's not a big deal.
I've gotten into the habit of hitting the 'cancel' button immediately after changing the channel in order to get the info off the screen right away. IMHO the huge info box is on the screen too long otherwise.
Not a bad idea...maybe I'll try automatically sending a cancel signal right after changing the channel.
Cell Phone interupting dish signal
Mapping An OTA Local
