: if I have 2 accounts at different locations in new York, one has standard receiver and the other with genie and genie minis. can i use one of the mini at the location that has the standard receiver
No ....: if I have 2 accounts at different locations in new York, one has standard receiver and the other with genie and genie minis. can i use one of the mini at the location that has the standard receiver
Yes really! The minis only work when connected to a genie.Really?
Good catch, assuming the standard receiver isn't on a swm setup, which the genie needs.Not only that, but I don't think the Genie itself will work with an old SD satellite dish...
If you reset it, I believe it should work in either location.I have a similar question to this .. if you've got 2 accounts one in New York and one in Florida both with Genies but only the new York account has a mini and you take that mini with you to Florida home, will that mini work on the florida genie ? Or is the mini tied to genie which it was authorized for ?
Sent from my SM-G920W8 using the SatelliteGuys app!
Limited time offer
