DirecTV Dish + Hughes LNB | SatelliteGuys.US
sat_fan
2
Hi fellows
I´m breaking my head with the following question.
¿Can i use a huges net. lnb on a RCA standard circular directv dish? ¿It is possible? I have the two components and i would like to put to work and no spend more money buying a hughes dish. Can i do this please???
Sorry if this place is not the correct to put this thread but i don´t know where.
Thanks a lot.
Salu2
scroll to the bottom right of this page to forum jump and select the Dish Network forum and goto Dish Technical.
to answer your question I believe you can but to get more opinions on this matter it would be good if you posted where i mentioned above .
By the way welcome my friend to the greatest satellite forum online!
:welcome
Why should he go to the Dish Network forums? He's talking about DirecTV equipment.
That LNB will work just fine on a standard round dish. However, you'll only be able to get channels from the 101 satellite.
sorry didn't notice that.:smug
Who does the install in the St. Louis Area?
hd dvr limit?
