DirecTV D11 sat receiver | SatelliteGuys.US
acuevas
SatelliteGuys Guru
132
Orange County
Hi All,
I have above mentioned receiver and want to know if I can use it for viewing OTA digital channels with-out a DirecTV subscription. Thanks.
Hi All,
If it works like the H20, then no. It must be activated in order to use the ota tuner.
You know thougfh, the unit does have an 'off air in' connection in the back vs an RF connection.
Yes, and that allows the unit to pass through RF signals from an antenna to a TV that's connected to it via coax/RF, that's all it does.
hr21-700 wont do IR and RF at same time
Seeking a straight answer about my second home
