Directv 5 (110W) | SatelliteGuys.US
Directv 5 (110W)
Crumbs
3
Montana
My dish is pointed and aligned to Directv 5 (110W) and the only tp freq I can get is 10809/14029/V but I can't find that transponder listed under that satellite???
Didn't know an FTA receiver could lock onto DTV. Think it's most likely locked to the echo satellites there. But don't think they 'normally' use that SR. <--reason it's unpublished?????
How do you know it's 'really' aimed at 110??
The receiver's LO frequency is probably set to 9750 and the LNBF LO is actually 11250
12309 is likely the actual freq. 10809 - 9750 + 11250 = 12309
Circular polarity signals can be received on linear type LNBFs with 3dB (half signal strength) loss. The OP is aimed at 110w, which has both DTV and Dish. I agree that it is very likely the received signal is Dish Network or a slight misalignment to an adjacent satellite with a compatible DVBS/S2 signal.
Need 8ft C Band Mesh Dish
New Mini-BUD C-Band Install (It Can Be Done!)* Part 2
