DirecTV 110 Sat Trouble | SatelliteGuys.US
gsxrscott
12
After a recent cold snap here in New Jersey, my reception of the DirecTV 110 satellite has quit. My dish is an 18 x 20 triple LNB, built-in 4 output multi switch. It was installed last July when we moved into the house. Running diags from both of my receivers shows a failure of the 110 LNB. The 101 and 119 passed diags fine. I ran the auto detect from my Hughes GABOA box and it is seeing my dish as a dual LNB. I picked up a replacement LNB form Ebay and installed it today and I am still having the same trouble. The only cables connected to the dish are the 2 that run to the 2 receivers. Is there a problem with the 110 satellite or is there something else I should check?
Thanks for the help.
Scott :mad:
What is an STB? I'm a satellite technology neophyte. I know enough to play with it but sometimes I need some help.
Thanks!
You mean set top box. I'm a real dummy sometimes. I'll try it but I am having the same trouble on both of my boxes.
:D
01/01-09/05 VE sells the HR10-250 for $850. delivered
Distorted picture problem
