tsduke SatelliteGuys Pro Original poster Feb 6, 2007 1,624 2 Iowa Oct 17, 2008 #1 Can a Direct dish be mounted in a E* mount? I wasn't sure how they differed. I know the tubes were a different size at one time.
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,711 10,252 West of the Pecos, between White City and Roswell Oct 17, 2008 #2 The Slimlines have a bigger mast, but the Phase III's on down are the same size...(Slimline needed for HD)
D Dashguy New Member Sep 17, 2008 4 0 Oct 17, 2008 #3 The mast for the SD Direct dish strips out to easy. Find it hard to also lock down the Ka Ku's on a pole mount....been using self tappers
iwc5893 SatelliteGuys Pro Feb 1, 2007 2,178 0 The desert of WA, zip code EIEIO Oct 17, 2008 #4 Dashguy said: The mast for the SD Direct dish strips out to easy. Find it hard to also lock down the Ka Ku's on a pole mount....been using self tappers Click to expand... I've never had one strip out...of course, I don't torque the bolts to "star torque"
