digiwave or spacestar fta receivers | SatelliteGuys.US
htownjoe
163
splendora tx
hello guys. my local fta supplier just got a shipment of digiwave fta receivers and sells them to me for 99.99. have any of you used one? why do you think they are so cheap? i give him 140.00 for every pansat 2700 that i buy. also one of my dish suppliers has a spacestar500 and he said he would sell it for 20.00. it should get real fta i would think. he said he was using it for free you know what but lost his contact, so i figure 20.00 for some real fta is not bad. howg spabc ba
I dont think either one have blind scan so you'd have to program in all the info.
I had a digiwave knockoff (KUSat 2600a...the review is in the review section) and it worked fine but with no blind scan it was set up for G10 only
I have a digiwave 7000 (my first FTA receiver.. yippee!). It's a decent receiver for the price - my dg7000 cost me significantly less than $99 shipped from a dealer though. It doesn't do the best job with motor control though.
For $20, I'd pickup the spacestar.. heck its $20!
just got another bud!
Dual signal help
