Digiwave 33"?? | SatelliteGuys.US
Digiwave 33"??
mrtrance
46
Anybody have any experience with this dish or company? Does the quality of the dish matter that much or the good lnbf? Which is more critical to getting good signal and picture quality? I ordered a fortec 80cm dish from an online dealer and it seem that I'm getting this other dish instead. I was wondering if this will work coupled with a Sadoun ku dual linear 0.4dB lnbf I bought. Please give some feedback.
it should work just fine. Some of the cheaper made dishes do warp easier especially in extreme temperatures.
I was using a Digiwave 33" dish but have now switched to a larger dish. It worked ok, but I found the lnb arm to not be centred exactly and somewhat flimsy. Also the tube for the base is thin walled an easily distored if tightened much. I am now using a Digiwave 39" dish (90x100 cm) and I like it a lot better. The lnb mount uses three tubes and keeps everything rigid and centred. Similar crappy mount tube though.
Titan Time Change
FTA Installer Southern California
