Digging up yard to run cable underground? | SatelliteGuys.US
foladar
FL
Does anyone have an idea how this is done? I swear he said something about digging up the driveway, but I was in a hurry so I didn't get to ask too many questions.
they do not dig up a driveway. They will bore under it. If its a "drop" (the line that feeds your house) then in most cases they simply put a small slit in the ground and push the cable under. If the guy is good you want even notice he did it.
If its a feeder/truck line then they may create a path about 6-12 inches wide. Still if they are good you will hardly notice.
To Be Announced
F compression connector question
