Different LNB on neighbor's house | SatelliteGuys.US
scottlaird
10
When did E start using LNB's that look like D's? My neighbor has upgraded to HD recentley and has a Dish 1000 with a 3 lense LNB. They are seperate. I have one larger 2 lense and a smaller 1 lense.
I was told by *E technician that they are required to do that now by *E. I have a 1000 system and was having problems and the tech removed by DPP Twin lnb that was used for 119 and 110 and replaced it with two single lnb's. I also have a DPP44 switch going to 4 receivers. He said the built in switch of the Twin sometimes interferred with the DPP44. Don't know if it is true but that is what I was told. It solved my issue.
Your neighbor has a dish 1000.2 with the integrated lnb. They are exactly the same they just dont have the cover over the lnb like previous models. This has been out for well over a year now.
And yes Chindman DPP twins do strange things with DPP44s but that is a seperate issue. A DP twin would be fine as well but DPP twins do not work well.
More Hd More Hd
Vip 622 to Vip 722 upgrade and external storage
