Difference in HD mirror channels? | SatelliteGuys.US
My question is, why do they do this? My second question is can you remove the xxxx numbers off of your guide without making a favorites list? Thanks!
Yes. Hit Menu -> 5 (Locks).
You can lock the system, hide locked channels and edit which channels are locked. They don't show up in searches, guides, etc. If you have a recording of a locked channel, you have to enter in the code to see what it is (or unlock the system temporarily to see). I locked out all the channels I don't want to see (most of the 9xxx ones, PPV, shopping, ect). You may want to keep an eye on it though, so you don't keep a channel locked that gets added later.
In short, it's an easy way to remove all the extra channels you'd never watch, or duplicates. And you can easily undo it.
Splitter will not work
Dish saves me as a customer yet again
