Dictionary | SatelliteGuys.US
Dictionary
Not open for further replies.
charper1
Bourbon Tester
18,442
6
I'm Nationwide
How can we add common use words to the dictionary. When I use LEARN it only skips that word again in the same post, but never learns it for later.
Also when will spell check be moved onto the regular post as opposed to having to go advanced?
The way it is setup only staff may click on the learn button, but I am not even sure if that works correctly.
The reason that is is not on quick reply is because in screws up the Ajax Moderation tools system which is used. (Its a new feature in this version of Vbulletin which makes moderation chores easy)
When I have time I will try to figure out whats going on with the Learn feature for the staff so that common words such as DVR, TIVO, SatelliteGuys and others are in there. :D
I would appreciate that as well Scott. Not that it is a top priority, but it would be nice for our everyday words to be included. Thanks.
what happened?
I have a weard problem.....
