We are moving and need to install a new dish. We are currently using western arc should the new installation be eastern arc?
At that latitude you would be wise to go with Eastern Arc..It's MUCH higher in the skyWe are moving and need to install a new dish. We are currently using western arc should the new installation be eastern arc?
WA signals are stronger. The problem is in northern latitudes 129 is very low in the sky. Which means that 100 foot tall spruce tree across the street may offend the line of sight. Crap shoot.Either arc will work.
I personally think western arc is more reliable around here.
If you need an extra dish let me know. Got a few dozen used ones at my store
Limited time offer
