Dell Recall | SatelliteGuys.US
Dell Recall
Not open for further replies.
weeeee :)
Wow! The ultimate "burn-in" !!
I have a 6 y.o. Dell Inspiron 5000 that also had a battery recall for essentially the same problem. Not only did Dell handle that with overnight service/no hassle return (put the return into the same box, relabel it with the provided label, and call an 800-number for a pick-up), but they gave us an additional battery and a $30 credit for our "trouble". The newer batteries also had a higher mA/hr capacity, IIRC. I'm still using both of them 5 years later, tho' their capacity has diminished a good bit. I hope they treat the current customers just as well, but with 4+ million to recall, that's a tall order...!
Potentially affected batteries were sold with the following models of Dell notebook computers or separately as secondary batteries:
* Latitude: D410, D500, D505, D510, D520, D600, D610, D620, D800, D810
* Inspiron: 500M, 510M, 600M, 700M, 710M, 6000, 6400, 8500, 8600, 9100, 9200, 9300, 9400, E1505, E1705
* Precision: M20, M60, M70, M90
* XPS: XPS, XPS Gen2, XPS M170, XPS M1710
The following battery models, only, may be subject to recall:
1K055, C5340, D6024, JD616, U5867, X5333
3K590, C5446, D6025, JD617, U5882, X5875
59474, C6269, F2100, KD494, W5915, X5877
6P922, C6270, F5132, M3006, X5308, Y1333
C2603, D2961, GD785, RD857, X5329, Y4500
C5339, D5555, H3191, TD349, X5332, Y5466
Dell Battery Laptop Recall Program
If you have a Dell laptop computer that was made between April 2004 and July 2006, there is an 18% chance the battery is being recalled because it may burst into flames. To see if your Dell laptop is at risk, go to dellbatteryprogram.com or call Dell at 866-342-0011. To be safe, remove the battery from the computer and run it solely on electricity. More. . .
Source: http://www.pcradioshow.org/
Sorry I did not see it and just heard about it now... I was out of the net for two weeks. Just catching up I guess :)
Home Insurance Quotes.
"HOT GAS" Costs U.S. Drivers over $2.3 Billion Per Year !
