Problem is I don't have DirecTV. Just need a poor man's MoCA-ish network and need external power at every node. PR kits are cheaper than SRs plus power, hence my question. Only trying to save a buck.
Glad to hear my plan should work. Thanks to all.
Great info, Roy. Thanks. What I'm planning to do is keep the DECA coax network completely separate from my cable tv coax network due to the DECA frequency walking on my cable channels and internet. I hope that using DECA II and having it isolated, that it will work nearly as well as MoCa. In my case I only need about 20Mbps speed, so even if the speed isn't great, that should be enough. I just need something more reliable than the powerline ethernet adapters I'm using today. So even if DECA isn't speedy, at least it's reliable. I would get Actiontec MoCa adapters, but in my 5 node system, that will cost me a fortune. DECA kits, on the other hand are only $12 each on ebay at the moment. So I can do my whole house for less than the cost of a single Actiontec adapter.
I'll post back once I get everything set up, and do some speed tests as well.
It was my experience that DECA only worked with DIRECTV set-up. What I mean is,that in addtion to using DECA for my DTV receivers,I did use extra DECA Cinema Connection kits with power inserters running from my DTV cable hook-ups to also run internet switches. However,they didn't work for me when I used them with my Cable company's coaxial cables. I actually did a thread one or two years ago about my experiment using DECA Cinema Connection Kits to run the internet through my DTV cable set-up to various internet switches,but I can't find the archive of it.
This is quite odd as I can create a patch cable by hooking two old white deca's together with power supplies. Ill give it a shot with black ones when i get some free time. But I have seen this work just fine. maybe your lines were crossed or you left the cable splitters in place. If you are trying to run the deca signal and cable tv signal over the same wire then you need the swm3 diplexors, theyre on solidsignal, someone do me a favor and link them, i gotta run out to eat![]()
Thanks guys for all the additional info.
Well, I got my DCA2PR0's installed and they are working beautifully, 100Mbps full duplex measured at every node. Mine doesn't connect to my cable tv coax network at all, so no need for diplexers or band stop filters anywhere.
I did attempt to put analog cable tv on the same cable as the DECA's using sat diplexers at each end. While I got my analog cable signals, it broke DECA, so that doesn't work. No problem in my case as I don't need it.
So anyone needing network connections elsewhere in their home which is prewired for coax only, this is a great solution.
Thanks again to all who contributed to this thread.
Perfect timing for this topic. Like MDAVEJ, I just cancelled DirecTV and will use the leftover deca (DECABB1MR0-01) plus some new DCA2PR0s to turn my house's coax into a wired network. The old DTV coax has no other signals traveling on it now; my cable internet enters the house on a separate, dedicated line. Wifi just isn't cutting the mustard for streaming and a robust work VPN, even when I move my N-router to different locations.
One question, if I may: Do I need to use a filter/splitter combo or anything else between my modem and the cable "pole/source" to keep my network traffic private from neighbors or anyone else outside? I don't think so, but I'm no authority or IT pro.
Many thanks!! Great info in this thread!
Yes I did. I could not get green lights on the DECAs after doing that. I expected it to work though. I'll give it another shot. Maybe I didn't wait long enough.With the diplexers,did you hook your DECA adapters to the power pass side of the Diplexer(with the cable analog signal hooked up to the non-power pass side) when you were trying to get your analog cable signals?
Question for you though, would THIS BSFR01 band stop filter be appropriate for blocking MoCA back to the head end?
Limited time offer
