DC HD Locals...Which channels? | SatelliteGuys.US
RedWings
841
Leesburg, VA
What are the HD channels for DC's locals? I get 004-00 that is in HD now and another NBC in the 6300 range that is HD. Last night I was watching a show in the 00#-) range in HD...but the equivilant channel in the 6300 wasn't in HD.
So what range is the HDs supposed to reside?
TIA
The 6300 range channels are the HD ones, if you have the local HD to map down, they will also be in the 004-00. If you hit the guide to go to the HD list, you will see all the HD channels you can have. Not sure why the 6300 channel was not HD. What the program not HD (black bars along the sides?) or was it just the program not in HD (not everything on networks are presented in HD).
The channel at 00#-00 was obviously HD. Its counterpart in the 6300s had black bars on the side and was cleary SD. I'll keep my eye out and update if I see this happen again.
If the channel is showing with black bars on the side it is an HD channel showing sd content. Wait till HD program is on and check it again.
I'm not sure if thats true. If I tune into a SD channel that doesn't have the HD option or HD counterpart, there will be black bars on the side displaying the picture in 4:3. The only way I can fill the screen is if I set my TV (Sony Bravia LCD) to zoom or wide-zoom. An example of this is MTV (Ch. 160) or anytime I watch a game with the NHL Center Ice Package (Ch. 540+)
You can use the 622 to do your stretching\zooming by hitting the * key.
Make sure this is set to NORMAL for both SD and HD if you are letting your TV do the work.
If there was indeed HD on the lower channel, you either went to the 6000 range channel when a commercial was on or you mistakenly went to the 8000 range channel. There is no other way this could have happened.
Share coax cable with DISH and FIOS?
Problem with DVR and FSN Ohio
