[Traxis] - DBS 3500 down | SatelliteGuys.US
[Traxis] DBS 3500 down
lazyfarmer
11
I have not used this old receiver for a while. Went into the menu with password and accidently pressed Delete All.
Screen is some menu I can't make out.Scrolling from top to bottom. Black and white. Did I erase the software or
affect the firmware. Serial number is 0512K00959. Is the proper load for this receiver for this receiver somewhere?
Thank you in advance.
I'm not familiar with that receiver but it sounds like it may have switched to PAL instead of NTSC format. Look for a button on the remote or the box labeled format, maybe video, or something like that, press it a few times and see if the picture straightens out.
I'm assuming that you're in the U.S., it could be the other way around if you're not, switched to NTSC instead of PAL.
*** The manual for the 3500 shows rescue : If you can see the menu, you want to try to select the TV System submenu (use channel up/down button on remote to select it in the System Menu screen) If you can do that, select NTSC from the listed choices by using volume +/- buttons on remote. If you try to reload the firmware, you have to be sure to pick the correct one, if I remember right, it varied depending on the serial number of the receiver. Later models of the 3500 were a bit different from the earlier ones.
Fortec Is there any active Ku band transponders on 81°W Galaxy 9?
hd9003pvr
