Daylight Savings Time | SatelliteGuys.US
Peter Parker
Formerly Geronimo
12,377
2,102
The schedule seems top have adjusted but my SkyFi2 still displays the standard time (even after I use the menu to ask for DST). Any idea when they will update the receivers.
Still off today. No one seems to know when XM will fix the problem. I guess i will just live with an inaccurate clock till they do.
More than likley it will change in 2 weeks when the time has changed in the past. My tivo's are still an hour behind because they moved up DST 3 weeks this year.
That just sounds odd/bad for TiVo seeing they are still in the set top business and ReplayTV isn't AND ReplayTV offered up a patch for all their set tops. It took less than 1 minute to perform and worked like a charm.
All my Sirius units changed correctly as well.
Mine are not connected to a phone line. Like 3 years now.
Forget Y2K! This is a major crisis......
Not.
However my SkyFi2 will keep songs in the buffer from 60-90 minutes ago....
Delphi says, "No Go"
I emailed Delphi support and here is there reply:
On 3/22/07, cetechsupport@delphi.com <cetechsupport@delphi.com> wrote:
Thank you for contacting delphi.com.
The device will continue to update on the old DST schedule. The SKYFi 2 receiver?s clock will update on April 2, 2007. We apologize for any inconvenience.
Sincerely,
delphi.com Customer Service
Sounds like we are stuck with this problem every year....
Problem goes away in two weeks until the fall. I'm sure they didn't expect the feds to mess with Daylight savings time, so it isn't something that can be modified like the channel lineups....
You would think though that you could actually change the time on the clock----or modify how it handles DST (especially since the menus indicate that you can). But you actually cannot. Not much to except live with it---and it will go away for awhile now.
Hey Ger,
So what was it that Sirius was able to do to get it right that other could not do? Even my old ReplayTV got it right? I know ReplayTV made an announcement at least 2 weeks in advance about the new DST, I never heard Sirius, did they just install a patch at their end?
I am nots ure what Sirius did. You would think that XM would tell us something.
I am not up to date on the subject because we do not observe DST here (and I really think DST is an absolute joke anyway), but is this new DST sched a permanent thing?
It is SUPPOSED to be permanent but there have been numerous complaints abnout it not resulting in the savings alleged. itake it that you are in arizona but are nota Navaho.
Yep, in the East Valley of PHX, but only a tiny % of Cherokee blood. My great (x3) grandmother on my mother's side was full-blooded Cherokee; but I am as white as they come. LOL. Not sure what the Native American slang is for that.
Well as Will Rogers said you have just enough white blood in you to make your honesty questionable.
BTW don't take taht too seriously you are a big help around here.
FWIW the problem went away sometime this past weekend. it now displays the correct time.
I ordered the SIRIUS Stratus last week...
XM Radio Debuts as a Standard Feature on Lexus LX 570
