Day Light Saving Time ? | SatelliteGuys.US
Shadowtester
166
Has anyone else checked out their timers for tomarrow after the DST shift. All my sunday timers are listed at the correct time however the Guide listing shows the programs I am looking at recording are 1 hour later. Anyone have any input if this will be a problem or will the guide correct it self after the actuall time shift occurs?
If you set repeating timers previously, yes they will correct themselves as soon as the time changes on the Dish system. However, if you set a timer today for tomorrow, there is a good possibility it will screw up. I got in the habbit of setting manual timers for specific times. That works fine.
See ya
Tony
echostar remote
Lip Synch Problems Still Evident
