Datastorm G74 satellite dish | SatelliteGuys.US
sean321
37
Des Moines
I have a customer that has this dish installed on her RV. I'm looking for any information on getting this dish to work with her directv receivers. Can it do SWM? Or is this really simple, i.e. it finds the satellites and all I have to do is activate receivers? :confused:
Isn't this Dish used for mobile high speed internet? I would think you would need a different LNB and or dish for Satellite TV....I couldn't find anything that says that dish is compatible with DirecTV....
you can add on directv to the data storm you tube vid shows a dual lnb probly just for 101 on the manufactures sight shows all types of birds to hit along with you internet..
it all depends on how your wired in that home . most have a switch box in the front cabinet that have all the runs to junctions in the home. older homes with a built in tv below the windshield will have its junctions on the pasangers side behind a removible box...
good luck
[ame=http://www.youtube.com/watch?v=aluEFwPZtJs]YouTube - DataStorm G74 Internet Satellite Deploymnet[/ame]
just took another look at that link for the manufactures sight looks like those are to replace the internet lnb for a SL5 or SL3 LNBF . An add on bracket for basic SD Direct or Dish will depend on what internet provider your using and what Streem they have you on. Some times its better to make it your self.......
What do I get with conversion to SWM?
One line or Two
