Darn Trees....I need 12 feet!! | SatelliteGuys.US
starpm
Help....just built a new home in the woods...200 ft driveway and the only place the Dish guy said we could get a good signal was near the bottom of the driveway, and then should be at least 10 ft high. We will eventually be putting a storage shed there, and can mount the dish on the roof, but we need a solution until then. My husband was looking at a design similar to a windmill base. Any ideas on mounting a dish 10-12 feet up?
I've seen dishes mounted on large trees. And they work. At least for a while.
Or att least until the wind starts blowing. We got our dishes in the winter and one was mounted on a tall aspen, the other on a tripod. When the ground thawed they were mounted on poles. Whenever it was gusty we briefly lost signal.
If you are trying to get more than 1 satellite on a dish (a Dish 500 or Dish 1000), a tree mount is not going to work very well. In order to get more than 1 satellite you have to "give up a little" on signal strength in order to get the others. So a little movement can go a long way.
Make yourself a telephone pole by cutting one of the trees on your property, sink it at least 1/3 of the length in the ground. Attach guy wires on 4 sides to counteract wind forces. Use a truck winch to pull the guys tight.
I'm certainly not recommending a tree mount. But the one I saw was on a large tree, and not very high. No wind movement. Just a convenient mount for a lazy man, I guess. Tree growth must affect it.
As long as you realize that a tree is not ideal and definately not a long term solution, and that it will need to be moved, you can always go with a tree mount depending on how long until you get a shed down there.
The nothing to bitch about thread!
Rave HD will be missed most of all
