D1000 in hunting camp | SatelliteGuys.US
IdahoDave
2
Idaho
Just changing from DTV to Dish today.
Have an extra D1000 3 LNB.
Am used to a single LNB on 110.
Since Dish peaks on 119, how hard is it to find the remainding 3, asumming the skew is correct?
they are geo sats, so it should go smoothly, yes?
Any info or help would be appreciated.
tks[
I think it is pretty hard. I gave up finding multiple sat's on one dish. I set up 2 dishes one on the 129 and the other using the 110 and join them with a switch. The 129 is hard to set up with just elevation and azmuth and a third plane skew is a challenge in the field. I travel in a motorhome and set up daily and often the 110 does all I want. Take a look at the dish pointer on this web-site and offers a lot of help. good luck
pretty sure direct is looking at sats with a degree or two of difference from what e* is looking at, it will probably be very hard
How to view TV2 in two rooms
Adding another receiver
