D1000.2 in South Texas? | SatelliteGuys.US
  • Thread starter Thread starter RedSavina
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
RedSavina
710
Groton, CT
I have read where the D1000.2 does not work in some locations - including my location in deep south TX (Harlingen DMA). I've also read where the D1000.2 will work in some New England locations despite being listed as otherwise. The other day I was helping a friend move when his installer showed up. According to the installer, the D1000.2 works in Corpus Christi and should work in this DMA...
I have questions about this:
1) How accurate should I consider these published exclusions? Better yet, does anyone know of a successful installation in my part of the country?
2) What is the actual problem with a D1000.2 dish in these areas? It can't be 129, since a separate dish can pull 129 with no problem... Besides, the local HD RSN is on 129! I assume it is the dish geometry.
3) Has anyone attempted installing the D1000.2 lnb assembly onto a larger (80, 90, 100 cm) dish?
4) I've read about a mod here and here to strap an lnb onto a D500 dish. Will this work in my area? Will it offer any advantages over a D1000.2?
I have been very happy getting my HD off of 61.5, but am considering "moving" and would need 129 to make the move worthwhile. Since I have Sky Angel on 61.5, re-pointing the second dish is really not an option. I'm not opposed to adding a third dish, but the cost of another dish and the DPP44 is a bit more than the 1000.2 solution (the 1000.2 lnb on a larger dish would be a wash financially, but might be worth it for the signal gains).
Note that I'm not bashful about doing my own install or getting a little creative/tricky. I've been installing my own gear for more than a dozen years - including 148 from the west coast (with the elevation offset adapter).
Bring it-
:D
Red
Trying to get Dish Network service, again
What are my Upgrade Choices
