D10 200 with 5lnb dish | SatelliteGuys.US
Liverpool
17
Dallas Texas
Hi
At present I have the D10 200 HD receiver with a 3LNB dish and a ota aerial Here in Dallas all locals are available in HD OTA. If I upgrade to the HR20-700 with 5LNB dish I know that I will have to run a seperate line from the OTA antenna to the HR20. Will I still be able to use the D10 with the 5LNB dish and multiplex the ota signal in with the sat signal as it is now in a seperate room.
Hi
First thing is the D10-200 is a SD receiver. Hopefully you have a H10 receiver even if you don't know what you have. The H10 will handle the five LNB dish as if it was a 3 LNB Phase 3 dish.:)
Nutshell, you must keep the OTA cable and the satellite cable separate.
The KA banded satellites transmit on a frequency that will overlap when joined with a OTA signal.
That means no diplexers or multiswitches that combine the signal. Unless you want a world of problems you keep the 2 cables separate.
Diplexers were fine before the KA banded satellites arrived, now they can no longer be used.
Audio Problem with HR20
using superdish?
