creekguy, need's help programming Dsr922 for Ku | SatelliteGuys.US
If its like the 905, its options 6-3-4 (memorize satellites)
That kicks you into the list of satellites
Also make sure the LNB's are set up (options 6-3-3)...I learned that the hard way. Saw C-Band but no KU...the box was set up for C-Band only :)
It should be options 6-4-4, if the sats are loaded
If they are not there Hit optons 6-4-2 and see if You are setup for Cband and KU
if You are just cband, You can change it there to both. then run the dish to G1-3
and wait about 20 minutes or so, they should load up.
Digital C Band Setup
Measuring Dish Size / Feedhorn Cover Is it needed?
