Cozi and NBC mux on Ku. | SatelliteGuys.US
VE2FCZ
60
25
St Rémi Quebec Canada
Hi all.
Using a Manhattan DJ 1997 HD i can get TP 12145 SR 19999 pretty good with 85 signal and quality 64 plus but i can't get Cozi on 11760 or Nbc mux on 11880.
I tried on 3 different dishes with no luck.
Are they H 265? my stb can only get H 264.
Thanks Bob. VE2FCZ.
I have a dedicated 90cm dish parked on 103 and it seems the LNB has to be skewed pretty far to the right for me to get everything on that sat. Not sure where you're located, but maybe try skewing the LNB a bit.
Reactions: primestar31
Just looking at COZI now. ON the Openbox S9, the Q is 75 and solid on a 33 inch dish. I did have to tweak the dish due to very high winds this past winter. All the other TPs are very good as well.
How to connect actuator/servo to receiver box
5G networks could wreak havoc on weather forecasting, officials warn
