Correct DECA Diagram? | SatelliteGuys.US
MightyMikeNice
19
Linden NJ
I have a SL3 and SWS8(not green label),3 H21 recievers and a HR22.
Would this diagram be correct for MVR?If not,where is it wrong and how so?Am I missing any components(BS Filters?)
I tried to search it,but I couldnt get reasonable results.Any help appreciated.
LNB---->PI---->BS filter--->SWS8
SWS8--->DECA--->H21
SWS8--->DECA--->H21
SWS8--->DECA--->H21
SWS8--->DECA--->HR22
SWS8--->DECA--->MODEM
••••••••••• ------>POWER SUPPLY
Did you see either of these? Do these apply?
The diagram on the left was some what helpful.Do I need the two way at the network connection with a SWS8?Will connecting the internet coax directly to the SWS8 without the two way work?Im thinking the diagram is like that because there is a 4 way splitter and no extra ports for the internet?
The diagram on the right would work for me. I don't have to relocate my SWM power adapter & I go that route,& I wouldn't need a band stop filter(if I buy the green labeled splitter).
Wireless adapter
Use my old big dish cabling?
