coordinates? | SatelliteGuys.US
coordinates?
shadymaple
south central pa.
Hello all, first time on your site.I Need some information on direct tv satelite coordinates for a high def install, I now have the regular directtv service but understand that the shot is a bit more south and I'm in a real bad spot, my zip code is 17314, thanks for your Help, Pete
You Lat/Long is PA 17314 39.7547 North and 76.3317 West
that's 39 degrees 45 minutes 17 seconds North Lat ( 39 deg 45.3 min North is close enough)
and 76 degrees 19 minutes 54 seconds West Long ( 76 deg 19.9 min West is close enough)
I think the OP actually wanted the aiming parameters for DirecTV.
Dish pointer is the place to go and use the lat/long that DandiDon supplied. You street address will also work.
If you use the street address you can zoom in on the map to see your house with the azimuth angle indicated on the map. You can move the mounting point around to find the best path through trees, etc.
Can't view other channel while recording
Gray bar on R22 when viewing locals
