Coolsat 6000 with multiswitch | SatelliteGuys.US
godfather818
52
Hey guys, I have a simple question. I want to install a 3x4 multi switch fron dual lnb. Is there anything I need to change in the receiver settings after I put up the switch? Also should I scan it directly connected to the LNB or connected thru the switch? Does it matter?
yeah thats pretty much it. No settings need to be changed on the receiver. Its just like you had a line from the LNB to the receiver
The multisiwtch allows you to have 4 boxes on a dual LNB.
Fortec 80cm azimuth setting
Friday Fun Poll 10/10
