coolsat 5000 hh90 motor 35 inch dish | SatelliteGuys.US
clower
10
i have a coolsat 5000 35inch dish and a hh90 motor. live in jackson mi 49201 this is what i came up with.
latitude42.32 longitude 84.34
dish elevation 38.5 (dish motor hh90) lat 42
174 true south <----------did i do that right
pole is plumb all the way around 2 1/2 in od 38 inchs in the ground concreated full. so with settings above set i got to menu and to motor to usals and pick closest sat which is at 84 degrees motor moves a bit but no signal. i move dish right to left (pole) than elevation on dish. still no signal maybe its my setting im useing i tried the all no luck no diseqc are installed.
is this a fta lnbf i have has the following on it
ultrasat
high band single
input 11.7-12.75 ghz
low frequency 10.75
please help any help would be apriciated thank you
WELCOME to the SatelliteGuys.US FTA forum, I would recommend removing the motor for now and finding and storing your true south satellite first.
I would use AMC 2/16 85.0W, not a lot on that satellite so you would have to ask here before pointing for a LIVE TP./Channel.
All the motor angles look good.
Code:
   Jackson, MI 49201
Latitude 42° 15.270'N Longitude 84° 23.250'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
  12.5°W Atlantic Bird   12.5W 102.4 109.3  4.6 -46.3
            Telstar 12   15.0W 104.2 111.1  6.5 -45.9
          Intelsat 901   18.0W 106.4 113.3  8.6 -45.2
                 NSS 7   22.0W 109.4 116.3 11.5 -44.3
          Intelsat 905   24.5W 111.3 118.2 13.3 -43.6
          Intelsat 907   27.5W 113.7 120.6 15.5 -42.7
         Hispasat 1C/D   30.0W 115.7 122.6 17.2 -41.8
          Intelsat 801   31.5W 117.0 123.9 18.3 -41.3
          Intelsat 903   34.5W 119.5 126.4 20.3 -40.1
           AMC 12/T 11   37.5W 122.2 129.1 22.3 -38.8
               NSS 806   40.5W 125.0 131.9 24.3 -37.3
             Pas 3R/6B   43.0W 127.3 134.2 25.9 -36.0
                Pas 1R   45.0W 129.3 136.2 27.2 -34.9
          Intelsat 705   50.0W 134.5 141.4 30.1 -31.9
          Intelsat 707   53.0W 137.8 144.7 31.8 -29.8
          Intelsat 805   55.5W 140.6 147.5 33.1 -28.0
                 Pas 9   58.0W 143.6 150.5 34.4 -26.1
              Amazonas   61.0W 147.3 154.1 35.7 -23.6
            EchoStar 3   61.5W 147.9 154.8 36.0 -23.2
             Rainbow 1   61.5W 147.9 154.8 36.0 -23.2
              Nahuel 1   71.8W 161.6 168.5 39.6 -13.5
             DirecTV 1   72.5W 162.6 169.5 39.7 -12.8
                 AMC 6   72.0W 161.9 168.8 39.6 -13.3
             Galaxy 12   74.0W 164.8 171.6 40.1 -11.2
                 SBS 6   74.0W 164.8 171.6 40.1 -11.2
               GOES 12   75.0W 166.2 173.1 40.3 -10.2
                 AMC 5   79.0W 172.0 178.9 40.9  -5.9
             DirecTV 3   81.8W 176.2 183.1 41.1  -2.8
               Nimiq 2   82.0W 176.5 183.3 41.2  -2.6
          Brasilsat B3   84.0W 179.4 186.3 41.2  -0.4
              AMC 2/16   85.0W 180.9 187.8 41.2   0.7
                 AMC 3   87.0W 183.9 190.8 41.1   2.9
                  IA-8   89.0W 186.8 193.7 41.0   5.1
             Galaxy 11   91.0W 189.8 196.7 40.7   7.2
             Nimiq 1/3   91.0W 189.8 196.7 40.7   7.2
          Brasilsat B4   92.0W 191.2 198.1 40.6   8.3
             Telstar 6   93.0W 192.7 199.6 40.4   9.4
             Galaxy 3C   95.0W 195.6 202.5 40.0  11.5
             Telstar 5   97.0W 198.4 205.3 39.5  13.5
             Galaxy 4R   99.0W 201.2 208.1 39.0  15.5
       DirecTV 1R/4S/8  101.0W 203.9 210.8 38.4  17.5
                 AMC 4  101.0W 203.9 210.8 38.4  17.5
            Spaceway 1  102.0W 205.3 212.2 38.0  18.4
                 AMC 1  103.0W 206.6 213.5 37.7  19.4
                AMC 15  105.0W 209.2 216.1 36.9  21.2
           Anik F1/F1R  107.3W 212.2 219.0 35.9  23.2
             DirecTV 6  109.5W 214.9 221.8 35.0  25.0
            EchoStar 6  110.0W 215.5 222.4 34.7  25.4
            EchoStar 8  110.0W 215.5 222.4 34.7  25.4
               Anik F2  111.1W 216.8 223.7 34.2  26.3
         Solidaridad 2  113.0W 219.1 225.9 33.3  27.8
              SatMex 5  116.8W 223.4 230.3 31.2  30.5
             DirecTV 5  119.0W 225.7 232.6 30.0  32.0
            EchoStar 7  119.0W 225.7 232.6 30.0  32.0
 EchoStar 9/Telstar 13  121.0W 227.9 234.8 28.8  33.3
            Galaxy 10R  123.0W 229.9 236.8 27.6  34.5
             Galaxy 12  125.0W 231.9 238.8 26.4  35.6
         Galaxy 13/H 1  127.0W 233.8 240.7 25.1  36.7
  Telstar 7/Echostar 5  129.0W 235.7 242.6 23.8  37.7
                AMC 11  131.0W 237.6 244.5 22.5  38.7
             Galaxy 1R  133.0W 239.4 246.2 21.2  39.6
                AMC 10  135.0W 241.1 248.0 19.8  40.4
                 AMC 7  137.0W 242.8 249.7 18.5  41.2
                 AMC 8  139.0W 244.5 251.4 17.1  41.9
            EchoStar 1  148.0W 251.6 258.4 10.7  44.6
            EchoStar 2  148.0W 251.6 258.4 10.7  44.6
 *** DBS SATELLITE ***
         EchoStar 3/R1   61.5W 147.9 154.8 36.0 -23.2
          EchoStar 6/8  110.0W 215.5 222.4 34.7  25.4
            EchoStar 5  129.0W 235.7 242.6 23.8  37.7
          EchoStar 1/2  148.0W 251.6 258.4 10.7  44.6
             DirecTV 5  110.0W 215.5 222.4 34.7  25.4
            DirecTV 7S  119.0W 225.7 232.6 30.0  32.0
Satellite Finder is (c) Copyright 2004, P. Lutus
my sat dont have 85 west on it it goes from 84 to87 do i need to add it some how?
Yes there should be a way to add a satellite (check the manual) , but any satellite close by will work. Let us know when you are just about to point the dish and someone will scan the satellite and give you a live TP./Channel. If its not listed on Lyngsat we can PM you a live one!
going to radio shack to make sure my lnbf is good and see if they have a sat finder. i will be back in 45 min and will than be ready to aim it. the manual i have is as good as a fire starter. not sure how to manualy add it totaly new to this. didnt think it was going to be such a challange. i dont even know how to add channel list i amaging with the stb program. is there a read me for setting up a coolsat and a hh90 motor. bought everything from go satellite and they refered me to this page.
thanks
hh90
the manual that came with the hh90 said to set as i did in the first post. than go to usals pick closest satelite than tweak in done. haha no signal at all.
:) Sadoun has great support for the products they sell, was one of the first web sites I visited when getting into DVB. You will learn a lot from there....
http://www.sadoun.com/Sat/Products/STAB/HH90-Stab-HH-Diseqc-USALS-Motor.htm
Dont think Radio Shack will be able to tell you if the LNB is OK, they do not deal with KU band satellite (Yet) 99% of the time the LNBF is OK, its always the first thing to be blamed and usually the last thing to be the problem.
Make sure the L.O. is set to 10750 in the antenna setup screen, find and store the true south satellite, then add the motor. Use usals, then refind the satellite and you are done!
ok im back and ready to aim can't figure out how to add a sat manualy so i was going for 84 brazilsat. you were right radio shack just has dish dtv lnb and no sat finders.
Thats a C-Band satellite so will not work for you!
Have another look at Lyngsat....
Four digit Freq. are C-Band
Five digit Freq. are KU Band (what you have)
info please
well as first posted my pole is 2 1/2 in od so putting my dish without the motor on the pole is out of the question cause it wont fit.. well no wonderi couldnt hit 83 being a c band. as i said i an new. i want to add 85 but dont have a clue how to.dont know what to type or where.lyngsat.... is a confusing web site. was reading i need to type in transponder and frequency? sorry im so ignarant. done tons of read over 16 hrs the more i read the more confused i seem to get. im willing to call someone from this room for step by step procedires over the phone.
or is there a post with pictures of screens and step by step sey up.
please help psb thanks for being patient with me
could you send me the stuff i need to hit 85 trying 82 with no luck. thank you get 4 bars but nothing locks in
I will scan the satellite and PM a LIVE TP. if I come across one........
Just did NOTHING at all on this satellite/s (85w)
ok i got 82 to come in i get 4 channels but when i turn to diffrent satellite nothing step 2.
gbn tv1 12143v nimiq service 1 and one other which is a black screen. is this 82?
Sounds like you probably have 82. There should be a couple (maybe a few) audio channels there as well.
It's either 82 or 91 (since the Nimiq reference) but if its 91 there will be plenty (a couple of dozen) audio channels. That's my true south bird :)
Little Help pls
Dish equipment
