Coolsat 4000 Pro Question | SatelliteGuys.US
PopcornNMore
3,635
128
Gibsonia, PA
How can I easily delete a satellite from memory that is not currently being used? I found that I can rename them and change settings. However, if one that you no longer want exists between others already programmed, how do you get rid of it?
I also wish that the Coolsat and other receivers had a scan and / or blind scan button on the remote that would automatically rescan a given satellite without going into the installation setup and entering a password.
Dave
There is a way to remove passwords...go to install and I think user setup. There is a menu that allows you to turn off the password protection :)
Huge newbie problem!!!!!
Telstar 5/Intelsat Americas 5 to Measat 2
