Connecting a 722 DVR to a Dish Pro 500 dish? | SatelliteGuys.US
forestwood
6
central illinois
I am new to the Forum, but could use some help. My motorhome has a Dish Pro 500 on a tripod. I am trying to connect a new 722 DVR. HD and locals are not needed. How can I connect this, or do I need Separators, Diplexers, or to change my LNB's?
Thanks, Forestwood
Since it's likely a DishPro LNB (not DishPro Plus), you'll need to run two cables from the LNB, to both of the receiver's "satellite in" ports. If it is a DishPro Plus, then you can run one cable, to a separator, to both of the satellite ins.
DishPro LNB's will not work with Separators, and diplexers will only be needed if you want to run a backfeed to a second TV
Thanks Matt. I already have 2 feeds from the dish 500. I will test it out tomorrow. You brought up a good question about the 2nd TV in the Bedroom. I thought I could cable from the back of the 722 to TV2. Your thoughts please! THX, Forestwd
You can run cable from TV2 on back of your receiver to your video distribution box (either AUX input or SAT input) and that will send the signal back to your bedroom TV
Thanks to all. I was able to get the Dish 500 working with the 722. Also figured that I can use the SAT input to run to the 2nd Tv. All went well after I ran a Check Switch.
I'll be using this valuable Forum again. Thx. Forestwood
Dish Internet team comes through (again)
SLEUTH CHANNEL OR NOW CALLED CLOO
