confused | SatelliteGuys.US
confused
Retired sfl
5
got my 921 current equip -dish 500 (119 & 110) dish 300-61.5,sw64, 2-6000 & 2-3800. will disconnect 1-6000 & 1-3800 to put in 921. my ? is my coax is old- marked "2200MHz" manual calls for 950-2150MHz or 2150 Mhz swept. can I use what i got, or need new ??
More than adequate.
2200Mhz exceeds the requirement of to 2150Mhz. Don't even need 950-2150 with your config, its really needed only with DPP, e.g. DPP 44 and dish seperator.
The 2150 MHz swept requirement is for using DishPro/DishPro Plus LNBs/switches. As you are using legacy LNBs/switches that requirement is not applicable. That being said the 2200MHz marking on your existing coax indicates that it has been sweep tested to 2200 MHz which exceeds the 2150 MHz sweep testing required for DishPro use.
Either way you should be good to go. Barring any damage/degradation of the connectors or cable, of course.
Thanks from both of you. I usually do all the work my self & this did have me comfused. I plan on replacing all connectors & I silicon all connections.
Why arn't more of you upset about this ?
Poll: 50x ,721 Owners - Would you pay for NBR?
