Confused by DVR Billing | SatelliteGuys.US
JRiz
44
Virginia
I know they've changed the pricing for DVR's. Can anyone tell me how much 2 vip 722's should cost me per month? They were charging me:
HD DuoDVR Receiver - $17
Solo DVR Receiver - $10
DVR Service - $6
$33/month can't be right!
i have a 625 and a 722 and mine is $17 for the second dvr and a $6 dvr fee.
i only have two total receivers, do you have more than the two 722's listed?
What you have listed there adds up to $33 and looks correct.
Tell us exactly how many receivers are on your account and exactly what they are. Then we may be able tell you if your bill is correct.
With two 722s and a solo, it's correct. First 722 is included. Second is $17.00.
So the solo dvr is wrong. I don't have a solo dvr, only the two 722's. So the total should be $23/month. That still sounds high, but better than $33 I guess. Thanks for you help!
If you only have two 722 receivers you should be paying $17 for the second 722 and $6 for the DVR. You may want to call them and ask where the solo DVR came from.
rv setup
Error 004 turning on or to a channel it appears and cancel clears it
