Configuration Questions | SatelliteGuys.US
herzzreh
61
Hi... I have my own dish (80cm required here). I want to hook up a regular ird in one room and a dual-tuner DVR in another room.
1) What kind of LNB would I need to get?
2) Any switches? thanks
Welcome to SatelliteGuys... dishnet or E* lnb's are "D" shaped Directtv or D* lnb's mounts are rectangular. You are talking sd (standard definetion) right? (althoght it does not matter) you would be better off with a dish 500 dish to get 110 and 119 (2 sats) and a dpp34 or 44 switch. You were talking new receivers right?(dp compatableA)
Thank you.
Dish 500 is too small for my location (I'm in Alaska).
Actually what I was thinking was getting the Wave Frontier toroidal antenna (worked fine for me down south), hooking up a dual LNB for 119 and a dual for 110 (Not using Dishnet LNBs). I already have the Dish 625 receiver. So how would I combine those 4 outputs to plug them into receivers two tuners (I still want each tuner to be able to tune independently both 110 and 119)?
Just curious, could the Dish Home Protection Plan cover obselence?
ClubDISH extended???
