Agreed, let me know if you'd like to have a tech setup.More than likely it is your dish that needs alignment or possible tree problem. Call Dish or a local retailer to come out and check on it.
Have you check the threshold levels to make sure that this isn't a signal issue? I am installed EA due to NLOS for WA where I live and I haven't noticed this on my 722. I will keep an eye out for this though. If your signal are above the thresholds, send me a PM with your account information and I will submit a Technical Problem Report.If it's a 722 with L676 software, it's more likely the software. There have been several threads about this problem. I've been getting it on the earc. And it's not the channel your watching. If you press guide then live TV you get the picture back and if you rewind, you'll find that you never lost the signal on that channel and all the video is still there.
The guide not updating sounds like either a failing receiver or something with the signal causing it not to be able to download it. Does the signal fluctuate while on the signal strength screen?I encounter the same problems at times. My dish is aligned as good as it gets as I compared my signal levels with the threshold and average levels and I meet or exceed those in most cases. The dish is tight and doesn't move. What gets me is, that it doesn't necessarily happen in bad weather. It sometime occurs with blue skies and sunshine as well. One time it was even so bad, that after it came back and told me that the guide was outdated and had to be updated. So I let it do it's thing and then after about 10 minutes it told me the update failed. Every time I went to pull up the guide this game started over. So I ran the system info check and all came back green. But the guide wouldn't update. Kept failing. So I rebooted and it still wouldn't do it. I pulled the plug, no dice. I then forced my way through and ran a check switch, that caused the receiver to reboot. After it came back, I tried running another check switch. It worked this time and also updated the guide. This has been a month and not a glitch again. You tell me what this was about. I thought I had another one dying.
On a side note: Whenever I am on a weak OTA channel and I switch to a Dish channel, the signal loss screen pops up more frequently. I work my way around this by switching to the strongest OTA channel first and then to a Dish channel. That works about 99% of the time.
Is this the partial signal loss message or the complete signal loss message?No the signal was actually stable and it's been several weeks now working as usual. That just happened on that one sunny day.
Limited time offer
