Compatible DVD to Direct TV | SatelliteGuys.US
mgafner
San Diego CA
Does anyone out there know of a DVD Recorder that is compatible (will change channels) with an IR Blaster on the Hughes Model H21-200 or even the H20 receiver?
I need to buy a DVD Recorder that can change the channels. I then finalize these shows and watch them on my laptop when I fly on trips.
You are an angel :angel: if you can help me.
Thank you
:) Mel
Thank you
:) Mel
D* generally doesn't release the codes for operating thier units outside of thier own remotes and the lagre universal remotes, I know of NO DVD R's that would change a channel on a D* unit.
The remote book that comes with refurb receivers lists codes for the RC64's to program to all d* boxes (used in the event you need a replacement for a hughes or samsumg/phillips box) ill rip one out of my truck in the morning and post the codes tomorrow night, if someone can beat me to the listing, have at it :)
Wouldn't it just be better to have the H21 autotune to the channel and then set up the DVD recorder to start a recording at the same time?
Or better yet, get the HR2x and then burn to the DVD recorder later.
R15 or R22 which is better?
Dual Co-Ax Question- Self Install of HD-DVR
