Commerical Software available to rip HD-DVD | SatelliteGuys.US
  • Thread starter Thread starter berck
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
berck
829
5
Pleasanton, CA (SF Bay Area)
http://www.slysoft.com/en/anydvdhd.html
Features
* Same features as regular AnyDVD
* Removes encryption (AACS) from HD-DVDs
* watch movies over digital display connection, without HDCP compliant graphics card and HDCP compliant display.
* playback of discs on the PC with PowerDVD Ultra, which otherwise do not run.
* Removes user prohibitions, you can select the language and subtitle track without going through the disc's menu.
* Removes parental restrictions.
* Allows you to remove or skip Studio Logos and warning messages.
* With "magic file replacement ™" you can remaster any commercial movie disc using simple XML scripts.
* The "must have" utility for the serious home theater enthusiast using a media center / home theater PC.
* Includes a UDF 2.5 file ripper, no need to install 3rd party UDF 2.5 filesystem under Windows XP.
PS3 Remote makes movie watching a breeze.
The Tier System For Blu-ray PQ
