Have an outdoor antenna, fta dish outdoors, how
can I combine the two, so only one cable comes
into the house? thnks.
While I am not a fta person, I see no reason a diplexer would nor work for you the same as it does on dish or direct.
try and run 2 cables if you can. I tried the diplexer route and the weaker antenna & sat signals were gone with the diplexer![]()
Every diplexer, no matter the brand, have an insertion loss. The minimum insertion loss is 1.5dB x two diplexers. It is best not to use diplexers if you have the option to run multiple coax cables.
Can someone shows us all how can we make the connection of the diplexer?? Also I know we will need an external switch so we can conect the coax from OTA
Thks
Limited time offer
