Combine 500+ and 1000.4 LNB's | SatelliteGuys.US
slaw2112
3
PA
The new 500+ LNB 110,119,118 w/ possible 129 addition has an internal switch. The old 500+ LNB did not. If connecting the new 500+ LNB to a 1000.4 E arch input, will this shutoff the internal switch in the 500+ ? Or must you use a 44 switch to shut off the internal switch ? Thank you for the help.
If you hook the new 500+ to the .4 it will probably give you a messed up check switch read it might bounce around dif sats every time your run it njot 100% sure though if you try it let me know what you come up w/ some good info to store into the ol Rolodex haha
Thats a good question.
We were told in a morning ATM that you can't use the new dpp 500+ with a 1000.4 LNB. We were told 2 dpp lnbs can't work together.
Totally newbie Dish 1000.2 + VIP211K hookup
Phone Call from Dish the Day Before a Bill is Due?
