Closed Caption Glitch | SatelliteGuys.US
Rod Williams
65
Huntsville, Alabama
I like to use the shortcut to access closed captioning. Yellow then 3. The glitch I am referring to is that when you are trying to turn off CC, the pointer is not positioned correctly(just above off) and requires you to move away and then back. This does not happen when you access CC the long way. Anybody else experiencing this little problem?
It does the same on my HWS.
Dan
Charlotte Locals screwed up tonight?
Slow channel changing on hopper
