Clicking Sound from 922. | SatelliteGuys.US
Huntress
38
Oceanside, California
My 922 has started making a loud metallic clicking sound that I usually associate with a Hard Drive dying. So far there are no other symptoms. What should I do now if anything?
Barbara
Have you tried unplugging the receiver from the electrical outlet for 10 seconds and plugging it back in? If it continues clicking after the hard reset, we will need to replace the receiver. Are you able to view programming? Do you have an EHD connected to your receiver so you won't lose your recordings? Please let me know. Thanks.
It looks like a power reset fixed it. Everything else works normally and I have an EHD that I copied the programming to as soon as the problem started. I will post here again if the problem returns. Thank you for your help Ray,
Barbara
Barbara
If you send me a PM with your phone number or account number, I'd be happy to get a replacement receiver sent out for you
My 211 Receiver Powers my External Hard Drive. Is this OK?
What is current software version on 922?
