Not only that, but I don't see where HopperGenie tells us which way his phone is pointing.Most likely you have no chance at that location, but it's hard to really tell from that pic how tall the trees are above the roof line
Yah! I was assuming he was generally pointing south/southwestNot only that, but I don't see where HopperGenie tells us which way his phone is pointing.
I am, it's for sats 62.5 and 72, so it is eastern arc and it's going to have to be through the leaves so I'm probably gonna to either cut them down myself(risk of injury) or wait untill winter or when the leaves fall out.
If your smartphone has a compass (mine doesn't), I cannot emphasize enough what NYDutch said above. Get that AR app on your phone and see if you can move the base of your dish around so that it has a clear LOS to 72.7. 136? What zip are you in?I know, the elevation is 44 and skew is 58 and azimuth is 136. Also I haven't received the dish yet but I do have the back assembly lnb and solo node, just waiting for arm and reflector to arrive
Good news! Your dish has been delivered, according to the UPS tracking. Enjoy!I know, the elevation is 44 and skew is 58 and azimuth is 136. Also I haven't received the dish yet but I do have the back assembly lnb and solo node, just waiting for arm and reflector to arrive
71107If your smartphone has a compass (mine doesn't), I cannot emphasize enough what NYDutch said above. Get that AR app on your phone and see if you can move the base of your dish around so that it has a clear LOS to 72.7. 136? What zip are you in?
Thanks!71107
Be careful. I've got red flags going off everywhere.Also I have found a new temporary spot that I can use untill winter when me and my grandfather will cut the branches off
The Solo Node can be mounted right at the dish so only one coax is needed for the run to the receiver. The one in the photo has been in use since 2013.Yeah that's what I was thinking but 1 I'm afraid of heights, 2. I don't know where to look for one that is super cheap, 3 The cables I have that go from the lnb to the solo node aren't long enough.
Limited time offer
