Circular, Linear, C/Ku Bands, Universal LNB | SatelliteGuys.US
  • Thread starter Thread starter dellsam34
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
dellsam34
16
Anyone has this on his motorized dish please give some feedback, I'm wondering what polarities this LNBF does and if there is another brand with better performance, the spec look good though:
Ku Band
[TABLE="class: table-collapse, width: 420"]
[TR]
[TD]Input Frequency
[/TD]
[TD]10.7-11.7 GHz / 11.7-12.75 GHz
[/TD]
[/TR]
[TR]
[TD]Output Frequency
[/TD]
[TD]950-1950 MHz / 1100-2150 MHz
[/TD]
[/TR]
[TR]
[TD]L.O. Frequency
[/TD]
[TD]9.75 GHz / 10.60 GHz
[/TD]
[/TR]
[TR]
[TD]Gain
[/TD]
[TD]56 dB Typical
[/TD]
[/TR]
[TR]
[TD]Noise Figure
[/TD]
[TD]0.3 dB Typical
[/TD]
[/TR]
[TR]
[TD]Switching Voltage
[/TD]
[TD]13/18 VDC
[/TD]
[/TR]
[TR]
[TD]Output Connector
[/TD]
[TD]F Type, Female
[/TD]
[/TR]
[/TABLE]
C Band
[TR]
[TD]Input Frequency
[/TD]
[TD]3.4-4.2 GHz
[/TD]
[/TR]
[TR]
[/TD]
[TD]950-1750 MHz
[/TD]
[/TR]
[TR]
[TD]Conversion Gain
[/TD]
[TD]65 dB Typical
[/TD]
[/TR]
[TR]
[TD]Noise Figure
[/TD]
[TD]13° K Typical
[/TD]
[/TR]
[TR]
[/TD]
[TD]13/18 VDC
[/TD]
[/TR]
[TR]
[TD]L.O. Frequency
[/TD]
[TD]5.15 GHz
[/TD]
[/TR]
[/TABLE]
BSC621-2 Built in diseqc switch
BSC621-2D diseqc has been removed to reduce interference, an external one can be used
h++p://www.dmsiusa.com/bsc621-2dpics.html
h++p://www.dmsiusa.com/bsc621-2dspecs.html
h++p://www.dmsiusa.com/docs/c-ku%20focal%20point.pdf​
choppy DCII audio
What is this?
