Cinema Question | SatelliteGuys.US
Cinema Question
mrmgroup
4
Michigan
OK – this comming summer - I am planning an extended trip in my RV to points north – including Canada. I have the ability to point my dish effectively. Some of my way points will provide me with a reliable high speed internet connection. Are there issues with connecting my receiver to a foreign (not normal) internet point and accessing cinema programming while traveling?
I guess the bottom line question is does D* care where you connect from, or are you limited to your home location?
You can connect anywhere you want. Could Directv tell, maybe. Is it likely, I don't think so. JMHO!
Use deactivated receiver for LNB power?
South Florida rain fade and installation?
